USB-to-Ethernet Adapters
USB-to-Ethernet adapters make it possible to connect a DI-720/730 EN-B product to your PC via USB 2.0. These affordable, easy to install adapters are ideal for customers who either don't have an available Ethernet port or are more comfortable connecting via USB.
Installation takes 60 seconds or less and once installed the USB-to-Ethernet adapter looks and acts just like a Network Interface Card (NIC). Communicating at up to 200Mbps these adapters make it possible to acquire data, gap free, at rates up to 380,000 samples per second (2 synced units tested at 190,000 S/s per unit).
Set up your Ethernet data acquisition network in four easy steps:
- Plug the USB-to-Ethernet adapter into a USB 2.0 port (follow through the Found New Hardware Wizard prompts to install the driver).
- Connect your DATAQ Ethernet device to the USB-to-Ethernet Adapter.
- Run the WinDaq installation program.
- Launch the DATAQ Instruments IP manager.
Plug and play installation and a transparent USB connection make USB-to-Ethernet adapters a quick, simple solution to your network interfacing needs.
