Specify maximum sample rate.
on Maximum Sample Rate….
Edit Preferences Maximum Sample Rate… (ALT, E, P, M).
Models |
Maximum Sample Rate |
DI-710, DI-715B, DI-718B, DI-718Bx |
4.8kHz |
DI-149, DI-155 |
10kHz |
DI-148, DI-158 |
14.4kHz |
DI-220, DI-221TC |
40kHz |
DI-200, DI-210, DI-722, DI-720-E (Rev A), DI-730-E (Rev A) |
50kHz |
DI-720-E (Rev B), DI-730 (all others) |
150kHz |
DI-2008 |
2kHz |
DI-1110, DI-1120, DI-2108, DI-2108-P, DI-4108, DI-4208, DI-4718B |
160kHz |
DI-720-USB |
200kHz |
DI-400, DI-500, DI-720-PP |
250kHz |
